Oil leak. need help. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-28-2010, 11:08 AM Thread Starter
crewcab68's Avatar
I have a 95 F-350 and there is a oil leak on the driver side I think its leaking around the oil cooler bit im not for sure. The bottom of the manifolds are wet with what look like oil.. Any suggestions....
Also where the steel fuel lines meet the braided line below the maifold seem to be leaking also. Does anyone know where i can get that line. Its about a foot long. I talked to ford and they told me the line is obsolete and ford no longer makes them. Has anyone else ever run into this problem.
Thanks
crewcab68 is offline
post #2 of 5 Old 08-28-2010, 02:07 PM
Keep this in mind (this is occuring in my truck) I have a leak coming from my turbo pedestal, but I have oil ALL over the bottom of my truck, on the rear diff, on the driveline, on the side of the transmission...
The fan and moving air blows oil everywhere, try steamcleaning or powerwashing your trucks under side to better determine right where its coming from.
tecster is offline
post #3 of 5 Old 08-28-2010, 04:06 PM
Powerstroke Techie
forddieseldoctor's Avatar
Thanks
The line you are talking about is a fuel line. Take a close look at your oil cooler condition. Mine rusted and pinholed and made a big mess. I had oil all over the exhaust manifold on that side, the steering shaft and the frame rail.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #4 of 5 Old 08-28-2010, 05:55 PM Thread Starter
crewcab68's Avatar
What is the best way to remove the oil cooler.? What all do you have to remove?
Thanks
post #5 of 5 Old 08-28-2010, 09:09 PM
did mine last year i believe its 3 bolts on one side and 2 on the other found it easier to take my inner fender well out and reach through that. oil cooler is all by its self on the side of the block so thats all you have to remove takes a bit of wiggling to get her out
95 F250 SC straight piped, 4'' lift, 35" bfg's, fpr shim, hpx, TS 6 pos chip. 247,000 miles and counting
Mdt1992 is offline
