I have a leak in the fuel return line going from the pressure regulator to the drivers side head. I'm having trouble getting the end that goes into the head disconnected and was wondering if there's a way to get it off without taking out the ac vacuum pump and all that
I used a open end wrench on my superduty when I made my fuel lines. Maybe take an old open end wrench and cut the box end part so you can slip it over the tube. Kinda like a flare but wrench.
Not really, Youll need to remove the belt, leave the AC comp on, and remove the bolts the hold the whole bracket that holds all the accessories on the bracket and just let it drop down and out of your way. No need to pull it completely out of the truck, just let it lay in the engine bay. A second pair of hands to put it back on helps alot.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
