Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Problem Forum > 94-98 7.3 Motor Problems
Old 11-06-2009, 12:19 PM
jmccall78373 jmccall78373 is offline
Send a message via AIM to jmccall78373
o-ring q's
my brother is driving my '96 and called and said that it is in need of o-rings for the oil lines that run under the valve covers. says it is a high pressure line. and the injectors. i already got the injector rings, but i need to know what the line is called so i can get the o-rings for it. any help would be great
Old 11-06-2009, 02:00 PM
adfields adfields is offline
High pressure oil line is what it's called and they are a pain to get into that little hole. You had better have a dental pick to remove it and I used a pencil and back of a drill bit to fish the new one in. To remove the line from the head pry the plastic collar down with a screw driver and pull the line off a bit like an air line. Then remove the fitting from the head so you can work on the O-ring inside.
On both of mine the plug in the back of the pump (HPOP) has failed multiple times so be sure you check it with a light and mirror or just replace it also.
You can get the O-rings at Ford or IH dealers but the link below is the best place to get the O-rings.
DieselOrings.com
Old 11-07-2009, 01:40 AM
thanks man
