1997 hard cold start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-30-2009, 08:44 AM Thread Starter
Angry 1997 hard cold start
Replaced GPR & GPS and it takes about 3-5 cycles turning key on and off before it will start when cold. When it does start there is a big plume of white smoke. Any ideas? Thanx
T.Nelson is offline
post #2 of 9 Old 10-30-2009, 09:02 AM
possible uvch or your compression is low. Just an idea i am sure a tech should come along soon with more insite. There are a tone of guys here with good advice.
sharky1320 is offline
post #3 of 9 Old 10-30-2009, 09:59 AM
That's the test every mechanic told me to do, for a quick check on Compression. I'd spend the $150 to get it looked at.
Proc is offline
post #4 of 9 Old 11-01-2009, 04:55 AM
cndrm's Avatar
Ok. Well, while your compression is most likely not where it was when the motor was new, I doubt it's that low. How many miles on motor? Yes, you could spend $150 to have your compression tested, or you could spend $30 on a manual, and $45 on a compression tester, and do it yourself. Or, if you really think your compression is THAT low, then just go to a shop and have your top end rebuilt. Personally, unless you've got well over 350K miles, I highly doubt your compression would be that low, unless the motor got dusted really bad.
What GPR did you install? Have you checked your output voltage on the new GPR? It is possible to get new parts that are bad.
mike
Don't burn your bridges, you might have to cross them again in life.
Don't sugar coat things. It covers up the taste of real life.
Providentia Remedium Belli
Early 1995 F-350 Crew Cab Long Bed
33" Hankook RT03 Muders
DIY Intake w/ Napa 6637 filter
3" DP to 4" exhaust
Want:
Charge Air Cooler
Adrenaline HPOP
Fuel System
Custom Tunes
Upgraded gear reduction starter
Bypass Oil System
Bypass/ Coolant filter system
Gauges
Built Tranny
cndrm is offline
post #5 of 9 Old 11-14-2009, 08:03 AM
jrcrane1's Avatar
Talking Hard Cold Start Exactly
Did you get this fixed? If not check to see if your relay is activating and for how long. Try unplugging your Oil Temp Sensor on the back ot the HPOP. I had the same symptoms and the mechanic showed me this. I know the GPR's are a problem but this problem with the OT Sensor should be included in the troubleshooting dialog more. Just a thought.
97 F-250 Ext Cab 4X4 Auto
298000 Miles
3" Down Pipe
4" Cat Delete Exhaust
6637 Filter Mod
Heavy Duty Stancor GPR
Baby Swamps Injectors "OMG"
jrcrane1 is offline
post #6 of 9 Old 11-16-2009, 02:08 AM
so if you unplug the oil temp sensor what will that cause or what problem does that isolate?
2000 F350 (7.3l)
2003 F550 (7.3l)
2004 f550 (6.0l)
2005 f750 (Cat C-7)
2006 f250 (6.0l)
2008 f350 (6.4l)
JasonZ is offline
post #7 of 9 Old 11-16-2009, 04:27 AM
jrcrane1's Avatar
Thumbs up Oil Temp Sensor
The way the mechanic explained it (also credit to cndrm on this site):
The GP's are controlled ultimately by the PCM. The PCM takes data from the Baro sensor, and the oil temp sensor, and determines how long to open the GPR (to send power to the GP's) for. So, in theory, if either the Baro sensor, or the Oil temp sensor were bad, then the whole system would not work correctly.
If when the dealer unplugged the oil temp sensor, and the GPR cycled regularly, and the GP's worked fine, then I would agree that your Oil Temp sensor is poo, and needs to be replaced.
Your problem I think, IS being caused by the oil temp sensor. If it's sending bad data to the PCM, then the PCM won't actuate the GPR for the correct amount of time. Change out the OTS, and go from there.
So far this has been the case as it has started everytime without being plugged in and it is getting colder here at night. 20's and below.
298000 Miles
3" Down Pipe
6637 Filter Mod
jrcrane1 is offline
post #8 of 9 Old 11-16-2009, 04:29 AM
jrcrane1's Avatar
Cool OTS
As a side note the new sensor came with a new connector and pigtail.
Maybe Ford knew!?
298000 Miles
3" Down Pipe
6637 Filter Mod
jrcrane1 is offline
post #9 of 9 Old 01-24-2010, 10:26 AM
Will a snap-on scan tool be able to check cam sensors and oil temp sensors. I have a 96 7.3 very hard to start cold, gpr tests good, glow plugs an harness new, enigne sounds like it has no compression, cranks very fast, and times only sounds lke it wants to start when letting off of the key, when it finally does start, ruins fine.
trunner_2000 is offline
