1997 PSD loses power - Ford Powerstroke Diesel Forum
post #1 of 31 Old 07-27-2009, 11:21 AM Thread Starter
My truck randomly loses power while I am driving down the road. It usually happens when I step on the gas pedal while towing my 5000lb trailer but not always. It will do it while I am not towing as well. As the RMPs start to climb to 2000 - 2500 range it will just seems to lose all power and the RPMs will drop way down. After I lay off of the pedal I can slowly get it to accelerate but it will cut out again as the RPMs increase. It has never completely died and it does not through any codes.
I bought it about a month ago and it has a complete Banks system on it. (power mod, trans mod, intercooler, and cold air intake.
Thanks in advance for any help you can provide.
jprice8553@aol.com is offline
post #2 of 31 Old 08-25-2009, 02:22 PM
Same exact problem!! Help!!
Same exact problem.... 97 F350 crew cab 7.3L stock with banks guage cluster, air bags, and TS Performance 6 position chip.... loses power at higher RPM's and eventually stalls.... if I kill it in neutral and coast for a minute, it buys me time... then restart and throw back into drive! This actually works... alternatively you pull over and let it sit for a minute before you start it back up again.... I bought it used with 94k miles.. loss of cruise control seems to be in sync with the problem... when I'm having this problem more often, the cruise control doesn't work at all... first had the CPS replaced by Ford... didn't fix it.... then I changed the oil which seemed to fix the problem for a month or so... then replaced the fuel filter and air filter... Problem eventually came back and cruise control loss started to manifest..... and then the vacuum pump finally exploded... pulley went loose and ****ed a bit and the pump exploded out the back... I replaced the vacuum pump and pulleys which seemed to fix the problem for about a month or so.... and now it's back.
I think that the vacuum system is involved here... initially I thought that the issue was the CPS.... the symptoms are very similar to the problems I've had with my 2003 7.3L Excursion, but I had that replaced... I'm seeing comments that the replacement CPS units are not all they are cracked up to be.... perhaps I should look at getting another replacement and putting it in myself?
What do you think fellas?
Aaron
Captain Gates is offline
post #3 of 31 Old 08-25-2009, 02:47 PM
Another note to add... The problem occurs usually at around 60 mph or higher and RPM's of around 2500 or so... Boost falls off on the guage and engine sputters as if it is a loss of fuel... the fall off continues and the vehicle loses all power until you pull over.
post #4 of 31 Old 08-25-2009, 03:37 PM
Exhaust Brake
Forgot to mention that there is an exhaust brake installed on my F-350
post #5 of 31 Old 08-25-2009, 03:41 PM
jbawilliams's Avatar
Are your fuel and air filters fresh? Either one being fouled will not allow the truck to run at those RPM's. It uses alot of both at 2500.
No trees were harmed in the sending of this message, however, a large number of electrons were terribly inconvenienced.
jbawilliams is offline
post #6 of 31 Old 08-25-2009, 03:59 PM
Both fresh... fuel filter needed tightening twice d/t fuel smell...
post #7 of 31 Old 08-28-2009, 08:40 AM
I started having a similar problem last night, I was driving home and my service engine light came on for about 3 seconds then went off... then 2 minutes later it came back on again and stayed on, when i went to accelerate nothing happened and when i stepped on the brake the service engine light turned off and i had acceleration again.. i just bought the truck about a month ago it has never done anything like that before.. the cruise control hasnt worked since i bought it if that means anything. please help anyone? any recalls i should be aware of?!
powerstroke72490 is offline
post #8 of 31 Old 08-28-2009, 08:44 AM
GM Duraturd's Avatar
I am thinking a weak HPOP. The fact that is in higher rpms makes me think that. The only think is it would modt likely throw a code.
jprice, I reccomend taking off the Banks Transcommand if thats what you mean by banks trans mod. I personally had it fry 2 of my transmissions and my tranny guy confirmed that the banks module was the whole problem. It makes the line pressures to high. Also many guys with tons of knowledge and experience in the diesel world say it is terrible for the transmission.
Nick, BPS Historian
1995 F-250 4x4 7.3 Powerstroke
Isspro Gauges, Tony Wildman Tunes, PSGH Stage 1 Injectors, Early 99 Intercooler, ATS Stage 6 E4OD, TCI Tranny Cooler, Snow Water/Meth, Traction Bars, EBPV Brake, TC Lockup Switch, Spray-on Liner, K&N Intake w/ NAPA 6637 Filter, 3" downpipe, 5" mitre stacks.
Waiting to be installed: Electric fuel with A1000 pump and Stealth DIY Dual HPOPs
GM Duraturd is offline
post #9 of 31 Old 08-28-2009, 09:24 AM
hi guys,
i have a 1997 7.3 td that wont rev over 2500 for the most part, and when i try to drive, i have a top speed of 37 mph! i hooked a scanner, and had no codes but i was reading exhaust backpressure of 46 psi when it "flattens" out at 2500 rpm.
any ideas?
dmallord is offline
post #10 of 31 Old 09-05-2009, 04:12 PM
Gentlemen,
My truck's been parked for 2 weeks now... I put in ANOTHER CPS, and I checked the IPR and brakes.... all is ok... but the truck is still stalling. Any ideas.... the truck loses power and stalls, but no codes are ever thrown.... seems like a loss of fuel to the system. I'm gonna get under the hood tonight.... where should I look? What should I check out?
Thanks,
Aaron
