PCM Wanted - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-22-2014, 07:42 PM Thread Starter
PCM Wanted
I have an 11/96 build date FSuperduty that needs a good PCM anyone have one laying around or know of the best place to purchase a good PCM please let me know. have cash/paypal/wire in hand if your in texas ill come get it thanks!
drillerjoe is offline
post #2 of 5 Old 06-22-2014, 08:52 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Probably need to provide a bit more info. What numbers are on your current PCM? Is your truck Auto or Manual, and do you know if it is a California truck or not? Cheers!
Patrick Feeley is offline
post #3 of 5 Old 06-23-2014, 05:29 PM Thread Starter
well thinking it may no be the PCM I am experiencing a loss of power with no cel but i am getting the p0603 code, which I am finding may be more to do with the programmer than the problem. I am also getting p0470 and p0478.
the truck
11/96 build date 1997 F Superduty (F450)
PSD
zf 5speed
3.5" down pipe and using a superchips micro tuner at the moment although I am likely to move to a 6 position from TS
otherwise the truck is completely stock
also fixing to go to 373 dana gears and need to resolve the power loss as I am sure it will become increasingly evident once I am regeared
post #4 of 5 Old 06-23-2014, 06:58 PM
Quoted: 8 Post(s)
The 603 code is from the tuner. 470 and 478 are exhaust backpressure codes. Check the EBP senor and connection and also check the EBPV butterfly to make sure it is not hanging up slightly shut, etc. Cheers!
post #5 of 5 Old 07-14-2014, 09:27 PM Thread Starter
got it fixed. turned out to be the back presure sensor $175 from ford for a new one and all is good
