Can't align my 97 ford f250? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 04-28-2014, 02:00 PM Thread Starter
fordman1988's Avatar
I just installed a redhead gearbox to get the slack out of my wheels, I took it to get an alignment and they told me they can't do it. I don't know much about alignments but I will explain the best I can. He told me the top of my tire is leaning too far towards the engine but he can not lean it the other way because my adjustment on the top ball joint is maxed out and they don't know why. Any ideas on what causes this? I was thinking maybe the front is sagging too much and need new springs?
1997 f250 4x4 7.3, straight pipes with stock dp (for now), dp tuner, diy intake, California fpr, pyro, trans and boost gauges. 3.55 gears
fordman1988 is offline
post #2 of 27 Old 04-28-2014, 02:05 PM Thread Starter
Does it seem to be sagging?
ID:	279729   Click image for larger version
ID:	279737   Click image for larger version
post #3 of 27 Old 04-28-2014, 02:08 PM Thread Starter
I believe he said it had negative camber but don't quote me on that.
post #4 of 27 Old 04-28-2014, 02:39 PM
Chop's Avatar
The camber is the vertical angle of the tire and wheel .Similar to say a wall stud which is a perfect 90 degrees Negative camber is never good unless you see it on the rear of a sports car .
These twin I beams have many moving parts as you can tell and I suspect the pivot bushings are worn first ,or ball joints secondly . Of course many will tell you it's cheaper to install a D60 than to pursue repairing these D50's but that's a different debate altogether .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #5 of 27 Old 04-28-2014, 02:52 PM Thread Starter
I wish I had the know how to do the d60 swap because I have nothing but problems out of this front end.
post #6 of 27 Old 04-28-2014, 03:00 PM
mjones3586's Avatar
have the same problems im seaching for a dana 60 and im swapping out
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #7 of 27 Old 04-28-2014, 03:01 PM Thread Starter
I just looked at the pivot bushings and they look good (from what I can tell) and the shop said my ball joints are good.
post #8 of 27 Old 04-28-2014, 05:43 PM Thread Starter
Anybody know if the leaf springs sagging could cause this?
post #9 of 27 Old 04-28-2014, 05:56 PM
RedneckYankee's Avatar
Yes weak sagging springs will cause this have the same problem with my 1996. My springs are sagging due to an incompetent shop replacing the with the wrong springs prior to me purchasing truck. Found out springs were rated for 2200 lbs (8 code springs) should have been (9 code/ W code springs). Can get truck aligned nor drive till springs are replaced
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #10 of 27 Old 04-28-2014, 06:08 PM
mjones3586's Avatar
i found a guy that has some springs for sell and cheap how do i tell which code they are and is thee any tell tell sign on dearching or sagging
4 inch lift o 36"s
