clutch flywheel question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-14-2014, 11:23 AM Thread Starter
speedracer7c's Avatar
So when I did my swap I bought a duralast/autozone clutch and flywheel set for my truck. I put my baby swamps in and the clutch obviously cant hold. I was wondering if anyone knew if i could run the duralast flywheel with a luk or valair clutch.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #2 of 4 Old 03-15-2014, 07:00 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I would be guessing, but I would say yes you could. You would probably need to give some flywheel dimensions to the supplier to verify that though. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 03-15-2014, 07:20 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
Just remember to have your flywheel resurfaced by a machine shop before the install of the new clutch.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 4 Old 03-15-2014, 05:31 PM Thread Starter
yeah I know, the clutch literally only has about 3k miles on it.
