Help! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-11-2014, 03:27 PM Thread Starter
7.3workacholic's Avatar
Help!
Experienced something very weird today, I just happen to be going about 45 and took it out of od, slowed down to about 15 and engaged it again and all off a sudden the check engine came on and the truck sounded like it was running on 2 cylinders, I put it in park and it eventually evened back out, I did it 2 consecuative Times. anyone know what could have caused this??
1997 F250 7.3 E4OD Centurion XLT 2wd, afe prodry s intake, diamond eye down pipe dump, tonys tunes, fpr shim, swamps idm, de-stickered and molded, smoked headlights,heavy duty rear suspension, Gearvendors, 2in level, 18in xd hoss on 35in terra grapplers, 8x8 steel rear bumper, in the process of black on whiting her
7.3workacholic is offline
post #2 of 8 Old 03-11-2014, 04:41 PM
aussie=effie
bob harris's Avatar
try a new CPS for starters, can happen like that
bob harris is offline
post #3 of 8 Old 03-11-2014, 04:44 PM Thread Starter
I replaced that darn thing not Even a month ago haha
post #4 of 8 Old 03-12-2014, 06:25 AM
Quoted: 84 Post(s)
Was it shifting weird/hard too? Check ICP sensor for oil in the connector and let us know what you find.
White95f250 is offline
post #5 of 8 Old 03-12-2014, 11:16 AM
Quoted: 50 Post(s)
Is the CE light still on? If so, get the code(s).
What brand of CPS is now installed?
madpogue is offline
post #6 of 8 Old 03-12-2014, 03:56 PM Thread Starter
No check engine light shuts right off after the engine evens out, and I bought it from the dealership
post #7 of 8 Old 03-12-2014, 04:31 PM
Quoted: 50 Post(s)
Code(s) _might_ still be stored. If I had to guess, I'd say it's UVCHs / wiring to the injectors. Sometimes one whole side will shut down if anything hinky is detected in any cylinder on that side.
madpogue is offline
post #8 of 8 Old 03-12-2014, 07:22 PM
Quoted: 84 Post(s)
Engine light goes out after it smooths out is what my icp sensor caused. As said above get those codes pulled and postem up.
