96 F250 PSD TTB Help3 - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-25-2014, 09:58 AM Thread Starter
mjones3586's Avatar
I just bought a 96 xcab lwb 4x4 with the TTB. Im looking to do a Dana 60 soon as I can get one and go through it and install. ard part is finding one around here.
Okay problem I'm having is that the other day I was drivng and heard a awful grinding noise metal to metal is the best to describe it. I looked and the passenger side caliper bolt were gone so got new ones put in. I drove about a mile or two and the noise came back. Only does it forward not in reverse and this is all in 2WD havent tried 4WD yet. I seen where to caliper was rubbing the inside of the wheel but isnt now.
When I bought it the guy said the manual lock outs were acting up and gave me a new set with the truck.
My question is can it be the manual lock outs doing this or something else I need to look at to determine this noise.
My fiance could feel the grinding in the floor board with her foot. It seemed after I fixed the caliper issue when in the throttle it would some times go away but not always.
This truck is running the 16.5 wheels and of course freaking 35x15x16.5 TSL Swampers so full turning i do rubb the leaf up front bout to change to BF Goodwrenches 35x12.5x16.5
Any help would be greatly appricatied I'm a mechanic just never ran into this. Some pics of the truck added sorry for the long write up but trying to explain much as possible if any other info just ask I will let you know.
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #2 of 15 Old 02-25-2014, 11:30 AM Thread Starter
mjones3586's Avatar
Some things that I have found that it could be
Spindle Bearings
U-Joints
Hub bearings
I only hear the sound on the passenger side
4 inch lift o 36"s
post #3 of 15 Old 02-25-2014, 11:59 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Sounds like bearings. Have you jacked up the front corners and spun each wheel? If you can feel it through the floor boards it shouldn't be too hard to find. Checks each wheel for play too ie: bearings and ball joints.
What did he mean by saying manual hubs are "acting up"? They either work or they don't. I suppose if you have a hub stuck in the locked position that's spinning an axle you could have an issue further into the diff but I doubt it.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 15 Old 02-25-2014, 12:11 PM Thread Starter
mjones3586's Avatar
I'm pulling it in the shop later today and jacking it up and checking each wheel. IDK what the guy meant jut said you had to back and pull forward more than usual but i havent had problem i have drove the truck for a week and a half now everyday no problems. I picked it up in Indiana and drove 4.5 hours home no issues not even a pull one way or the other just rough ride with those Super Swampers.
I have the new manual hubs in a box still he gave me didnt see a problem putting them in but i have turned the ones it now and they are in free with ease.
i have been told on another site to check the spindle bearings
4 inch lift o 36"s
post #5 of 15 Old 02-25-2014, 12:39 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
Yeah there are two big bearings per side that your whole hub assembly rides on. One inner and one outer. I bet one of them is piled up. When you pull the locking hubs off you might even find metal shrapnel in there.
-JJ-
JJFLASH is offline
post #6 of 15 Old 02-25-2014, 01:06 PM Thread Starter
mjones3586's Avatar
okay i just went out tried 4wd a little difference not much. i pulled in the shop and jacked up one side at a time and nothing on the driver side but the passenger side i could shake the wheel rotor and all like it was just loose.
4 inch lift o 36"s
post #7 of 15 Old 02-25-2014, 01:18 PM Thread Starter
mjones3586's Avatar
well im going to say wheel bearing and race might just be the problem im going to pull it down tomorrow after work hopefully.
4 inch lift o 36"s
post #8 of 15 Old 02-25-2014, 07:01 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
Yup if you have play like that and a growl you will need both bearings/races for sure. There is a special socket you will need to deal with the nuts. I'm trying to remember how the d50 comes apart vs the d60. It's very similar though, just a little difference in the nuts/washers etc. Iirc you will need heavy snap ring pliers for the 50. 60 has more of a spring retention thing you can get out with screw drivers. If it's all loose and chewed up your nuts may be loose enough that you can spin them out by hand but you will need the special socket to tighten it back up and seat the bearings properly.
-JJ-
JJFLASH is offline
post #9 of 15 Old 02-25-2014, 08:52 PM Thread Starter
mjones3586's Avatar
Alright thanks for that info I will check with my guy at the auto parts store he is a old school gear head. I'm hoping to tear it down one day the week and put it all back together saturday
4 inch lift o 36"s
post #10 of 15 Old 02-25-2014, 10:19 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
You bet. It really isn't a complicated job. Basically just need the socket and snap ring pliers. Rest is basic hand tools. Grease, rags, parts cleaner, good heavy punch at least 12" long to drive the old races out of the hub, hammer, Allan wrenches for the locking hubs...that's about it.
Oh a case of suds and a buddy help the job too lol
-JJ-
JJFLASH is offline
