Front wheel bearing - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-11-2014, 03:26 PM Thread Starter
Front wheel bearing
Took my truck to get tires, and when I went to pick it up the shop told me I had a front wheel bearing going bad. I was going to change the rotor anyway considering its toast, so my question is if there is any special tool (besides the spindle nut tool) I need. or any extra parts I should replace while im there?
ex. do I need a bearing separator or anything?
what would I need for seals?
austinlibke is offline
post #2 of 10 Old 02-12-2014, 06:51 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
I'd replace both bearings and the seal...
CT Performance, Inc. is offline
post #3 of 10 Old 02-12-2014, 06:59 AM Thread Starter
As in, drivers and passengers, or there are two bearings and seals on one side
post #4 of 10 Old 02-12-2014, 07:08 AM
jesilvas's Avatar
Quoted: 3 Post(s)
2wd 4wd? Not sure if that matters on an OBS. Dually or not?
I know on my SD DRW 2wd, it's a regular hub, with two bearings, an inner grease seal, and races. I pulled and repacked them like I do trailer hubs.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 10 Old 02-12-2014, 07:11 AM Thread Starter
Its a fwd and single rear wheel.. I know my brake rotor is bad. And I'm just looking to see what I'll all need for parts and tools..
post #6 of 10 Old 02-12-2014, 05:19 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
If you're in there, I would replace both bearings ... inner and outer, races, and seal) on each hub. Cheers!
Patrick Feeley is offline
post #7 of 10 Old 02-15-2014, 09:34 AM Thread Starter
as well as spindle seals and spindle bearings? just reading through O' Reillys website and seeing things there..
post #8 of 10 Old 02-15-2014, 01:28 PM Thread Starter
I just took apart another hub, gunna turn the rotor and use that in replace of mine, was curious on if itd be a good idea to reuse the bearings and seals in that hub sense it all seemed okay.. Id repack the bearing of course.
post #9 of 10 Old 02-15-2014, 01:31 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I check bearings, but usually they are ok. Seals, heck no. New every time.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 10 Old 02-15-2014, 02:09 PM Thread Starter
I only noticed one seal, on the back of the hub, where is the second?
