NO CLUE! CAN YOU GUYS HELP!!!!! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-22-2014, 09:47 AM Thread Starter
dirtbiker109d's Avatar
Hey guys. ever since i bought my truck its mad a "knock" when i turn. But its only when it rains. Its just one knock. no idea what it is. my whole front end was checked and worked on last year. ball joints races, bearings hubs, everything. whole 9 yards. what could it be? sounds like a ****ing leaf spring moving side to side.
dirtbiker109d is offline
post #2 of 10 Old 02-06-2014, 07:36 AM
Quoted: 75 Post(s)
I'm surprised no one has replied to this. I have the same issue when going up drive ways etc. It's a knock and it confuses the hell out of me BUT I do believe it's a sway bar issue. I need to double check it with someone else in the truck but i've ruled out exhaust and any front end issue as well as a leaf spring issue.
White95f250 is offline
post #3 of 10 Old 02-06-2014, 04:21 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Try tightening the fender bolts by the hood hinges (don't laugh ... just try it). Cheers!
Patrick Feeley is offline
post #4 of 10 Old 02-06-2014, 06:26 PM
Quoted: 48 Post(s)
If the truck in question is the one reflected in your user name, i.e. an F-250, it's not a sway bar issue. Your truck, presuming it's stock, doesn't have one.
madpogue is offline
post #5 of 10 Old 02-06-2014, 07:57 PM
Quoted: 75 Post(s)
Sorry but I do have a front and rear sway bar on my truck. Thank you for your comment.
post #6 of 10 Old 02-08-2014, 03:53 PM
midnite rider's Avatar
Quoted: 285 Post(s)
see if your front shocks are loose. they do come loose sometimes for no apparent reason
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #7 of 10 Old 03-05-2014, 06:40 PM
Nitro41's Avatar
Yup. It sounds like its coming from the floorboard on my truck. All new EVERYTHING when i put the D60 in my truck. Makes a pop noise when still or low speed.
Just did nee front ubolts....springs are tight.
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #8 of 10 Old 03-05-2014, 08:08 PM
mjones3586's Avatar
samething in mine and its the passenger shock heres a way to check. Go out and grab your shock and see if you can move it at all. On mine i could so i had to replace the lower shock bushings
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #9 of 10 Old 03-05-2014, 09:40 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
if not ball joints then id say the drag link. sometimes it can pivot and make a thump. i know mine occasionally does this as well as my dads f250.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #10 of 10 Old 03-06-2014, 07:12 AM
astrong513's Avatar
my truck made the same noise but it was in my shocks both pass and driver bushings were trash
astrong513 is offline
