Loud vibration/shake at 55mph - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-09-2014, 02:21 PM Thread Starter
I get a vibration/shake at 55mph and continues as you speed up. I checked all axle joints, bearings, and drive shaft joints and everything's good. I had the tires balanced but nothing is solved. I was wondering if anyone encountered this mystery or has any idea what it could be? thanks
'97 4x4, 6637 Riffraff intake, 4" Straight pipe
smill24v is offline
post #2 of 11 Old 01-10-2014, 08:19 AM
Quoted: 54 Post(s)
4x4 or 2WD? If 4x4, manual hubs, and are they locked?
madpogue is offline
post #3 of 11 Old 01-10-2014, 01:52 PM Thread Starter
4x4, manual hubs and they're not locked. I'm stumped
smill24v is offline
post #4 of 11 Old 01-14-2014, 02:12 PM
I'll be keeping my eye on this thread as I have vibration from 60mph up. If I keep it under 60, there's nothing.
DChalue413 is offline
post #5 of 11 Old 01-29-2014, 05:38 PM
Carrier bearing maybe?
ksumark is offline
post #6 of 11 Old 01-30-2014, 04:46 PM
94Powerstroke_97303's Avatar
Possibility of the tires being off weight? Maybe have your tires rotated or re balanced... I have had the same problem and got it resolved by having the tires rotated and re-balanced...
Hope that helps...
'94 F350 7.3l PowerStroke Turbo Diesel 5sp
CrewCab 4x4
A lot of new OEM parts, add a leaf in the front.
94Powerstroke_97303 is offline
post #7 of 11 Old 02-02-2014, 01:32 PM
Check the pinion bearing for being loose If it is then it the crush sleeve has or a ujoint is Mose shake the rear driveshaft
hlzceller is offline
post #8 of 11 Old 02-02-2014, 01:33 PM
Check the pinion bearing for being loose If it is then it the crush sleeve has or a ujoint is loose shake the rear driveshaft
post #9 of 11 Old 02-03-2014, 02:09 PM
midnite rider's Avatar
Quoted: 285 Post(s)
is there a hum with it, if so could be rear hub bearing sounds familiar
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #10 of 11 Old 02-10-2014, 02:08 PM
Quoted: 285 Post(s)
All the balancing weights still on driveshafts. U haven`t hit a deer or something rolled up under the truck possibly hitting rear shaft. just covering bases.
-Tom
