Unable to remove rear drums - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-06-2014, 09:09 AM Thread Starter
svranger25's Avatar
as the title says i cant get the right rear off, i have retracted the shoes and the drum still wont budge, hit it with a hammer a few times and nothing,
any ideas or things i missed?
are there retaining rings i'm not seeing, hub bolts or something like that?
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #2 of 6 Old 01-06-2014, 09:50 AM
PSDTV21's Avatar
No retaining rings or any funny. Get a bigger hammer, rent a drum puller, or hit it with some heat. If none of that works cut it and replace the internals afterward
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 6 Old 01-06-2014, 11:10 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
yup, hammer, puller, or hot wrench.
There are youtube vids
GD
Heavy_GD is offline
post #4 of 6 Old 01-07-2014, 08:01 PM Thread Starter
svranger25's Avatar
I forgot my own motto "if all else fails, get a bigger hammer"
gave it a few good whack with the 5 lb and it came off, the shoes on right side were good left side on the other hand are worn to metal and past that its all bad!
replaced everything on the inside,
how do i adjust these drum brakes, still have a loose pedal and it gives to the floor
-Brandon-
post #5 of 6 Old 01-08-2014, 09:00 AM
Quoted: 50 Post(s)
Wow, NO ONE has suggested PB-BLaster? Or Kroil? Get a full can of one or the other and shoot it around where the hub slides over the drum, and the holes for the lugs. It's obviously rusted into place along that back surface and/or the hub bore. Give it part of a day, then SPIN the drum and hit it from BEHIND with a small sledge at several different places around the circumference of the drum. Get some ear protection; the neighbors are gonna think you've founded some funky new church, with all the ringing. I had to give one of ours probably 50 whacks, spinning it all the while, to eventually get it loose.
madpogue is offline
post #6 of 6 Old 01-08-2014, 05:32 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You can manually adjust the brakes through the hole in the bottom of the backing plates. To tighten up the shoes, you can rotate the starwheel with a screwdriver. It will "ratchet" over the self-adjusting lever in this direction. To loosen up the shoes, you rotate the starwheel in the opposite direction, although it will not ratchet over the self-adjusting lever in this direction. You need to use a small scewdriver (or piece of stiff wire) to push the lever off the starwheel. Cheers!
Patrick Feeley is offline
