Need help hub is trashed - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-16-2013, 09:09 AM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Well im stuck in lexington TN right now and the truck is at a shop. Im pretty sure the inner wheel bearing blew out, not sure how with only 1000 miles on em, but the hub let go and the spindle is trashed and im sure the hub is also. Ive got a spindle on the way but i have no idea where to get a front hub. If anyone knows where to get one or if someone has a spare please let me know. thank you, tony
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #2 of 7 Old 12-16-2013, 09:26 AM
Interior Guru
weareweird69's Avatar
Quoted: 104 Post(s)
Feedback Score: 3 reviews
Any D50 or D60 HUB will work, but it needs to be from like 90+ older D50's had D44 size hubs. I threw the word out for you, I can probably get you a hub, but I cant get it out that way for a few days with shipping.
-Garrett
Too many projects. Too little time...
weareweird69 is offline
post #3 of 7 Old 12-16-2013, 09:42 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
i have a spare hub and anything else you might need, but i'm in MD
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 7 Old 12-16-2013, 10:22 AM
Matthew82's Avatar
I could probably get my hands on a hub or 2 myself but I have no way of getting it to you. Although I'm in Alabama so I'm probably closer than anyone of us the commented
Originally Posted by fordmandan87 View Post
Matt are you on the sauce?
All 3 at the same time? Who do you think you are, Charlie Sheen
Matt the odds of you convincing the guy he's not in possession of a kryptonite vagina that commands top dollar for the hour is lower than me getting to bang a millionaire midget on mars during a meteor storm
Matthew82 is offline
post #5 of 7 Old 12-16-2013, 10:49 AM Thread Starter
95redrifle's Avatar
Quoted: 3 Post(s)
Well ive got a buddy back home shipping me the one off of my old D50. I appreciate the help guys. Hopefully they can get me back on the road sooner than later
tony
1997 F250 4.10's
south bend clutch
post #6 of 7 Old 12-16-2013, 11:11 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
The number one killer of our hubs is people who dont know what they are doing putting them back together (no insult intended). What happens is there is an inner bearing nut that has a pin on it. Tighten that down to the needed specs then install the locking ring (ring with a lot of holes in it and an alignment tab). People usually just ram those in there. What needs to be done is that pin lined up to work into the locking ring. If that pin is missing on the inner bearing nut that should be replaced as without that lock the inner bearing nut can back off without anything to stop it. Ive run into this issue a few times myself while checking front ends out
Trucks and parts............
kanuck15 is offline
post #7 of 7 Old 12-16-2013, 01:35 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I have one in the floor I've been kicking for months, pm me if you still need it, I can next day it and I'm in north ga so closest
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
