superduty zf 5 to 4x4, Can it be done? looking for solid info. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-14-2013, 09:02 PM Thread Starter
theforeman57's Avatar
Quoted: 4 Post(s)
So a quick question. My folks have a 89 f 350 4x4 C&C dually w/a 460 / c6, and its dead. The solution that we came up with is to put a 7.3 idi / zf 5 in it.
(I should note that we found a good running 89 superduty with our motor and transmission in it)
Now the question. Could a guy swap a rear tail shaft housing from a 4x4 onto that transmission and hook it up to that transfer case? Thanks!
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #2 of 3 Old 11-16-2013, 07:37 AM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
If the superduty trans has a parking brake mounted on it the answer is yes. Remove the parking brake assembly and bolt the transfer case in place. If it does not have the parking brake on it then no, would be a complete tear down to replace the output shaft.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 3 Old 11-17-2013, 12:14 AM Thread Starter
Quoted: 4 Post(s)
Thanks for the response. I should of updated this thread the other day when I got my answer from another thread. I appreciate it!
Axel --> 16yo
