Cant find rear axle yoke part - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-22-2013, 06:59 AM Thread Starter
Broke slide in yoke piece that slides into rear diff. Anyone have a part number or a place to get this?
Thx.
1997 F350 Black & Lifted CCLB OBS PSD
Purchased Sept. 2012 w/183,000 miles
deanc24 is offline
post #2 of 4 Old 09-22-2013, 07:43 AM Thread Starter
possible match
I found a number on the part.
Spicer 03-3-789
I was able to find some possible matches.
Not sure if it is right.
Can anyone provide some confirmation?
Thanks
Rockwell/Meritor 135N-3-488KX
Neapco N3-3-488KX
Spicer 3-3-488KX
Northern Drivetrain, LLC: Spicer 3-3-488KX
deanc24 is offline
post #3 of 4 Old 09-22-2013, 07:51 AM Thread Starter
correction
OK, slight modification to clear up any confusion.
The slide yoke piece that is broke, actually slides into the shaft support that connects the front and rear drive shafts. It doesn't slide into the rear diff. Sorry for the confusion.
deanc24 is offline
post #4 of 4 Old 09-24-2013, 06:20 AM Thread Starter
Parts Found
OK, after much searching and deliberation, I have finally determined the parts necessary to complete my repair. Dennys Driveshaft web site and the Quad 4x4 web site both confirm the same thing.
My 1997 PSD 4x4 CCLB has a Sterling 10.25 rear end that uses 1350 series pinion yoke. 3-5/8" measures across the u-joint (from cap to cap) and the caps are 1-3/16" in diameter. This is a 31 spline pinion yoke. The slide yoke (connects front drive shaft to rear drive shaft is a 1350 series 1-1/2" spline diameter, 16 spline yoke, with the same cap to cap and cap diameter measurements.
Denny's Driveshaft has all the parts and was very helpful.
However, due to too many people modifying their setups, they do not go by manufacturing specs. You have to physically measure your parts and give them the specs. This eliminates the need to return parts that are not the right size. This was frustrating at first, but afterwards seems kinda obvious.
deanc24 is offline
