steering issues PLEASE HELP. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-10-2013, 04:41 PM Thread Starter
Hello I have a 1994 F250 7.3 5speed. It's all stock and original I'm currently having problems when turning right. Everything is fine turning left but from straight to right it's very hard to turn like no power steering. I replaced the steering pump and still have problems, ball joints have been replaced.
oldschooldiesel is offline
post #2 of 10 Old 09-10-2013, 08:59 PM
Quoted: 54 Post(s)
2WD or 4x4? How's the alignment?
Check steering gear mounting to frame, column/shaft (esp. joints), don't overlook the obvious -- tire pressure.
madpogue is offline
post #3 of 10 Old 09-11-2013, 04:22 PM Thread Starter
4x4 fresh alignment new tires, A friend told me it's the ujoints in the axle i'm having trouble believing him and someone told me the gear box. I'm not sure where to start. and update on the issue with the new pump it only does it when still and sometimes at slow speeds. so i'm really confused with it.
post #4 of 10 Old 09-11-2013, 04:23 PM Thread Starter
when looking at the gearbox anything in perticular to look for to show thats it's the problem
post #5 of 10 Old 09-11-2013, 05:26 PM
Quoted: 54 Post(s)
Could be the U-joints. Try this - park the truck with the front wheels dead straight. Unlock the hubs, and try to turn each front axle shaft. Then turn the steering a few degrees and try turning the shafts again. If it's much harder, or you can't turn them, the U-joints are suspect. Lubricate if they're greaseable, replace if not.
Are you sure the hubs are unlocking? Are the the OEM autocraptic hubs?
madpogue is offline
post #6 of 10 Old 09-11-2013, 05:47 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
X2 that's what happened to me but i had hard steering right and left
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #7 of 10 Old 09-12-2013, 01:55 AM Thread Starter
Manual hubs i will try that tonight when I get home from work.
post #8 of 10 Old 09-20-2013, 08:40 PM
blue72's Avatar
Feedback Score: 5 reviews
Bad axle u-joints can be hard to diagnose, but this could be your issue.
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #9 of 10 Old 09-21-2013, 05:44 PM Thread Starter
Got right side u joints changed after many hours of fighting with they were beyond bad but still have hard right steering. But still have to do drivers side but have to wait till better weather.
post #10 of 10 Old 09-23-2013, 04:35 PM Thread Starter
Replaced all ujoints, with no help in poor power steering to the right. it works perfect to the left. Only thing left that I know of is to change the steering gearbox. I'm not looking forward to this repair.
