touchy and slow returning brake pedal - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-27-2013, 12:48 PM Thread Starter
Send a message via AIM to jeremy2146 Send a message via MSN to jeremy2146
So, Ive put my old ford back on the road, but the brake pedal is really kinda touchy, and it returns pretty slow. I have good vacuum and everything seems to be working it just aint right though. The master cylinder was replaced before I bought it at a shop. Any suggestions? Could this be the booster going bad? or air in the master cylinder?
jeremy2146 is offline
post #2 of 9 Old 08-27-2013, 01:23 PM Thread Starter
I just did a search and found someone else was having a similar issue and they adjusted the rears amd it fixed everything so im going to try that tonight
post #3 of 9 Old 08-27-2013, 03:33 PM
Quoted: 44 Post(s)
What do you mean by "touchy"? Does it lock up too quickly?
madpogue is offline
post #4 of 9 Old 08-27-2013, 04:30 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
When my booster went bad, the pedal almost seemed to "suck" to the floor and then "delay" on the return (meaning normally it would follow my foot back, but when the booster was bad, it would not ... slight delay). Cheers!
Patrick Feeley is offline
post #5 of 9 Old 08-27-2013, 04:38 PM Thread Starter
Ya im kinda leaning towards a worn out booster...it seems not so bad sometimes but other times i have to pull the pedal back up with my foot...dont know if that another sign of a worn out boosteror not.
post #6 of 9 Old 08-27-2013, 08:13 PM
Quoted: 8 Post(s)
Mine was never that bad. Cheers!
post #7 of 9 Old 08-27-2013, 08:30 PM
Quoted: 44 Post(s)
So it wasn't that touchy, Feeley?....
Sorry...
madpogue is offline
post #8 of 9 Old 08-27-2013, 08:57 PM
RedneckYankee's Avatar
When I had problems with my 96' the pedal acted as if there was air in the lines. Pedal real spongy but would somewhat pump up. Pedal was a little sluggish to return but not bad. If you got onto brakes hard she'd lock up the fronts. Found rear adjusters froze up. Got them freed up, greased and adjusted properly brake pedal works great and returns normal. You may have frozen adjusters but sounds more like booster problem. Good luck
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #9 of 9 Old 08-28-2013, 12:34 PM
Quoted: 8 Post(s)
Sorry...
Cheers!
