Dana 60 Swap Hub Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-28-2013, 02:50 PM Thread Starter
I have searched the forums and counldnt find an awnser. I have a ttb now and the calipers bolt on the dana 60 I have is ball joint with clip held calipers. My question is will the clip held calipers work with my bolt on caliper hub is the rotors the same size. Any help would be appriciated from those who know.
95 F250 4x4 Extended cab, diy intake,3" downpipe, 4" Exhaust, moon visor. fuel fill mod,custom overhead console,custom underseat diy sub enclosure trans, egt,boost,oil press, volt, water temp gauges, dana 60 swap,
Bubbac308 is offline
post #2 of 3 Old 07-28-2013, 09:46 PM
JSchuricht's Avatar
Around 94-95 Ford changed from slide pins to bolt on calipers, the rotor size also changed by about 1/2". As long as you use the same style axle, the rotors and calipers will swap between the D50 TTB and D60. You cannot mix the slide pin and bolt on calipers and rotors.
JSchuricht is offline
post #3 of 3 Old 08-07-2013, 01:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The hubs will swap fine tho, but as said no rotor or caliper swapping
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
