Front Drive shaft options - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-16-2013, 01:22 PM Thread Starter
nightmare95's Avatar
Hello guys, i tried searching but came up with nothing. i have a 95 f250. i put a dana 60 under it and a 6'' lift. my driveshaft is too steep of an angle and starts vibrating at 40 kmph. i had it for a year like this and its time for a change. Right now the driveshaft is the stock f250 and is darn near completely compressed once its on my truck. I measured the distance from yoke to yoke and came up with a measurement of 42''s i was under the impression that the f350 driveshaft with the double cardon joint will fit length wise, is this true? or do i need a custom built driveshaft.
Thanks for any help
nightmare95 is offline
post #2 of 9 Old 04-22-2014, 12:54 PM
yamaSauRX's Avatar
No responses?
I too am searching this subject. Going from stock TTB Dana 50 on a 1996 F250 to a ball joint 1997 D60 with stock F350 springs. Later on I would like to do superduty springs and a RSK kit, but not right away.
Will my stock driveshaft work for now with the D60 and stock 97 springs up front?
My truck has a ZF5 speed, not auto. I've seen some discussion of the front driveshaft being differnt length for the different transmissions. Is that true?
Thanks
yamaSauRX is offline
post #3 of 9 Old 04-23-2014, 03:26 PM
Quoted: 48 Post(s)
Yes, front driveshaft length varies based on transmission. But a front driveshaft from an F350 with a ZF5 should fit a Dana 50 retrofitted F250 with a ZF5.
madpogue is offline
post #4 of 9 Old 05-12-2014, 06:54 PM
leojr's Avatar
Quoted: 4 Post(s)
I will be making the switch soon from my D50 to a D60. I made a specific point to collect the D60 front drive shaft with the double cardon joint as I have read in many places that the D50 shaft will fit and work but causes vibrations about 40mph that the D60 shaft with its double joint does not have.
The front drive shaft will be the last thing I address during the swap, as I can do that another weekend. Because this also requires the yoke on the transfer case to also be swapped from the D60 donor vehicle.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #5 of 9 Old 05-14-2014, 12:37 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
This is incorrect, the flange on the T-case will be the incorrect one.
To the OP, what year is you truck? Or if you know if your T-case is a 1356 or a 4407
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 9 Old 05-14-2014, 12:50 PM
yamaSauRX's Avatar
I wasn't the OP but I have a 4407. I purchased a F-350 shaft from a ZF 5 truck with the double cardan joint.
Now I need a pitman arm from a f350 and the yoke for the front of my t case.
post #7 of 9 Old 05-14-2014, 07:07 PM
ol_Blue97's Avatar
The double cardan joint yolks for a 4407 can be hard to find. There is a company on eBay selling reproductions for $150 I think
FRANK THE TANK
post #8 of 9 Old 05-18-2014, 06:34 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I swapped in a stock 95 f350 axle on my 97 f250 with nothing else, the 4407 front driveshaft fits fine with new u joints on a solid axle swap
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 9 Old 05-18-2014, 04:00 PM
ol_Blue97's Avatar
The 250 shaft will fit just fine, but to propery of the swap you need the double cardan joint due to the yoke being lower on a Dana 60. Due to the increased angle of the shaft and u joint angles not matching the double cardan joint is required for vibration free 4x4 use
FRANK THE TANK
