AXLE SEAL !?!?!? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-12-2013, 05:07 PM Thread Starter
AXLE SEAL !?!?!?
hey guys i have a 97 f350 7.3 4x4 and the left rear axle seal was leaking, when i took it apart i found that someone put some kinda of F'ed up axle seal repair kit thing on it..... the axle seal housing was kind of pitted with rust when i pulled it all off, i emery clothed it up and made it all smooth again and put the new seal on, it was ok for about a day or two and then the MOFO started leaking again.... does ANYONE know what i can do or where i can get this seal kit from?! someone.... PLEASE HELP. i do not want to have to buy a new axle housing
got coal? is offline
post #2 of 5 Old 06-15-2013, 04:11 AM
leojr's Avatar
Quoted: 4 Post(s)
Is your vent hose clogged? Don't blow into it, you'll only put the blockage into the axle tube, remove it then blow it. Also remove the vent nipple/brake line T thingy holder bolt to and clean it. Otherwise, I have nothing for ya.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #3 of 5 Old 06-15-2013, 03:44 PM
Quoted: 818 Post(s)
Its probably not a f'd up seal kit. That's how they come from the the manufacturer of the seal kit. If its a sheet metal looking tin can type, its called a speedy sleeve. Its also used for the rear main repair kit from Ford. When your seal mating surface gets pitted with rust or has a groove in it, that's what you use to obtain a nice new surface. Also the tin can piece is a hardened alloy steel so the seal won't rub through.
Corey@CNCFAB is offline
post #4 of 5 Old 06-15-2013, 03:48 PM
ZMANN's Avatar
Quoted: 1668 Post(s)
agreed
We Miss you Ronnie
ZMANN is offline
post #5 of 5 Old 06-15-2013, 06:28 PM Thread Starter
thanks guys, yea i ended up just not tightening the ratchet nut tight enough in fear of burning up the bearings, but now its tight and all is well! i see that nifty speedy sleeve, that is pretty cool ive never seen one before.
