front axle help 95 f250 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-16-2013, 09:29 AM Thread Starter
Tivs's Avatar
So i know my ball joints r shot and prob needs new springs. But b4 i go buying parts what y'all think i should repair. My problem is negative camber and when reversing extreme negative camber as well as tire directions being different from eachother like one tire slightly turned the other straight. Only happens in reverse
SOLD: 99.5 F-250 ECLB, Zoodad mod, aih delete, 22k mod, wix 46637,16.5s wrapped with 35x12.50 BFG T/As s, ccv mod, 140v IDM, heater core ball valve mod, 324,000 miles
95 F-250 ECLB, E4OD, 3in turbo back straight piped, diy intake w/ 6637 and riffraff prefilter, cool go fast stickers, 140v idm, need new ball joints and king pins...negative camber is out of this world. 266k miles
Tivs is offline
post #2 of 13 Old 05-16-2013, 04:02 PM
Quoted: 53 Post(s)
The only "repair" for this is a Dana 60 conversion. This is just one of those things the TTB 50 does in reverse. It's not like you're going far/fast enough to affect tire wear. But yeah, it does look disconcerting after you back into a parking space and step out of the truck. If you don't like the way the truck looks after backing in, just pull forward a foot or so before shutting down....
madpogue is offline
post #3 of 13 Old 05-16-2013, 06:19 PM
Gaius's Avatar
Quoted: 43 Post(s)
New springs helped my truck out a lot. So much so that I have slightly positive camber now. Makes it so I am feathering the outside of the front tires. I rotate them a couple times a year. Springs were only $150 at the local spring shop.
If you do the springs, do them first so you can see if you need to adjust camber on the upper ball joint.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #4 of 13 Old 05-17-2013, 12:28 AM Thread Starter
Tivs's Avatar
Ya im familiar with the tbb just never owned one. Ya yesterday i had a guy running at me at fredmyer yelling "stop your axle is falling apart". I just wanted to make sure i was on the right track about ball joints and springs. I might just do a add a leaf and ball joints. I wanted xpr but should i just roll with moog or spicer?
Tivs is offline
post #5 of 13 Old 05-21-2013, 04:32 PM
Gaius's Avatar
Quoted: 43 Post(s)
I only install Spicer ball joints in everything I own. Moog quality seems to have gone down a LOT int he past few years.
05 F350 Crewcab
Gaius is offline
post #6 of 13 Old 05-21-2013, 09:56 PM Thread Starter
Tivs's Avatar
Ya bought me some spicers cheapest ones believe it or not. Anywho putting em in tomorrow. Hopefully this fix it...well still needs springs
Tivs is offline
post #7 of 13 Old 05-24-2013, 12:12 PM Thread Starter
Tivs's Avatar
New ball joints r in and camber is great goinstraight but still backing up my toe and camber r all over the place. Please tell me new springs will fix it
Tivs is offline
post #8 of 13 Old 05-24-2013, 01:11 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A d60 will fix it, the d50 is notorious for ****ed wheels when backing
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 13 Old 05-24-2013, 09:01 PM Thread Starter
Tivs's Avatar
It just upsets me a month ago it never did it this bad
Tivs is offline
post #10 of 13 Old 05-25-2013, 09:02 AM
Gaius's Avatar
Quoted: 43 Post(s)
Can you take a picture of it?
Edit: A little camber in is normal when backing up, what's the camber when it's stopped after going forward?
05 F350 Crewcab
Gaius is offline
