E4OD hard 1-2 shift, no codes... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-15-2013, 08:13 PM Thread Starter
Gaius's Avatar
Quoted: 40 Post(s)
97 F250 7.3. Last year I installed a 6.0 converter, new cooler, and a Transgo Tugger kit. Wildman tunes.
The past few days I've had a hard 1-2 shift, the rest feel fine. Light or hard throttle. However, it has shifted fine a couple times. Except for once in a while after downshifting from OD to 3, the shift back to OD is real hard.
No OD light flashing, no check engine light, but I haven't had it ran for codes yet.
Any ideas?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #2 of 3 Old 05-18-2013, 08:44 PM
Blazin8556's Avatar
Mine did that for a little bit. Did you put the shift kit in? There was an optional 1-2 spring that is supposed to remedy hard shifts. I actually wish I didn't put mine in.
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #3 of 3 Old 05-21-2013, 05:32 PM Thread Starter
Gaius's Avatar
Quoted: 40 Post(s)
I did the kit myself. But I've put at least 5k miles on it since then. And the hard shifts just started. I don't remember exactly, but I know I wouldn't have worried about too hard of shifts when installing. I did open all of the holes to max.
I'm wondering if something's wrong with the accumulator. I may put the old spring back in, just don't want to drop the pan right now. In the middle of building another Jeep.
05 F350 Crewcab
Gaius is offline
