time for rear spring mounts...... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-13-2013, 05:17 AM Thread Starter
Ranzan's Avatar
Quoted: 23 Post(s)
just got my truck back from the body shop yesterday and the owner said my pass rear spring is really bad......
took a quick look and holy crap only about a 1/2 of metal still holding so i need to go get the mounts hopefully find someone that has them in stock today
my question is the bushings... does anyone know if the front and rear bushings are the same? i have a set of front bushings sitting around that never got used
not a big deal to get new ones but if they work i will use the set i have
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 4 Old 07-28-2013, 08:00 AM
noticed one of my rear spring mounts is cracked also did you get the mounts from ford ,a junk yard or?
trailerpuller#3 is offline
post #3 of 4 Old 07-28-2013, 05:37 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
NAPA carries them for around $32.00 ea, just bought 2 for my truck today, former owner replaced the rear, this week I am going to replace the front rear spring hangers. As far as the bushings, go to an auto parts site, look up the bushings and see if they are the same.
dirtcrew51m is offline
post #4 of 4 Old 08-27-2013, 08:07 PM
The front spring bushings are larger than the rear spring bushings i believe. Not the same size
'95 ECLB XLT 4x4, E4OD, K.P. D60, 4:10's, 221k, TW custom tunes, 1st Gen Lightning 40/20/40 seats, Wicked Wheel 2, Bar None Bellowed Up-pipes, 360* thrust bearing, Garret Deleted Pedestal + H.F. Outlet, 6.0 fan, CCV dump, Melling LPOP, HPX S.S. oil line, Stancor GPR, 203* T-Stat, MBRP 3" D.P. to 4" exhaust, Tymar Intake, IssproEV2 gauges, Aeroforce Interceptor, Adrian Steel Box, Lund Screen-Front, Donaldson Air & Oil Filters, 2nd Owner
AccordinToJordan is offline
