Spindle bearing and wheel bearing parts problem - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-01-2013, 05:25 AM Thread Starter
USAF-FD-NJ's Avatar
Purchased spindle bearing (pn# 382-a and 387-a) wheel bearing (pn#38) from Napa for my 1997 F350. Neither fit over the spinal. I don't believe Napa gave me the correct bearing can anyone help they are skf bearings. Should I go back and spec for a 1996 F350?
USAF-FD-NJ is offline
post #2 of 13 Old 04-01-2013, 05:37 AM
JBRIXEN's Avatar
return them, they gave you the wrong part. you need napa # BK6.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #3 of 13 Old 04-01-2013, 05:39 AM Thread Starter
USAF-FD-NJ's Avatar
Can you supply me with the correct inner and outer bearing numbers.
Thanks for the big help
post #4 of 13 Old 04-01-2013, 05:47 AM
JBRIXEN's Avatar
outer - BR38
inner - 387a/382a
how close are they to fitting? may have to polish a little with emery cloth. they can be a VERY tight fit and have to go on perfect or they will bind. a little grease will help.
JBRIXEN is offline
post #5 of 13 Old 04-01-2013, 05:54 AM Thread Starter
USAF-FD-NJ's Avatar
outer - BR38
inner - 387a/382a
Those are the ones I have. The inner does not fit over the last hump on the spindle. I have used grease and used a some super done sand paper to take out the rust and such.
Also my old bearings did not have these rings
post #6 of 13 Old 04-01-2013, 05:56 AM
JBRIXEN's Avatar
what is the number on the old and new bearing that wont fit? if legible.
JBRIXEN is offline
post #7 of 13 Old 04-01-2013, 06:01 AM Thread Starter
USAF-FD-NJ's Avatar
Not legible
post #8 of 13 Old 04-01-2013, 06:05 AM
JBRIXEN's Avatar
what about the new bearing, what is the number stamped on that?
JBRIXEN is offline
post #9 of 13 Old 04-01-2013, 06:14 AM Thread Starter
USAF-FD-NJ's Avatar
New- m7g skf 387a (inner), ...J skf lm104949/q for the outer
post #10 of 13 Old 04-01-2013, 06:20 AM
JBRIXEN's Avatar
thats the correct number, i would trade it with a different one when you get the new spindle kit and see what happens. measure original, current new and another new at napa and see what you come up with.
JBRIXEN is offline
