Noise problem after throwout and pilot bearing install - Ford Powerstroke Diesel Forum
Old 03-11-2013, 03:52 AM
My throwout bearing grenaded. Had a guy put all new bearings in it. Said pressure plate,clutch and everything else looke like new. Picked it up and started to make a noise like a belt squeakin. I have a little play at top of clutch and when I barely push it in it quits. I called him and he said drive it for a week and the play should come out of the clutch pedal and the noise should stop. Does this sound right to any of you?
Old 03-30-2013, 07:01 PM
if your throwout bearing grenaded find it hard to believe everything else looked new. dual or single mass flywheel?
Old 04-05-2013, 04:12 PM
Had that same thing happen to me when I swapped in a zf5 behind an Idi we forgot to pack a little extra grease in pilot bearing it eventually quit making noise and is still in service today bout 8 years later
