Truck shake violently at 55 mph - Ford Powerstroke Diesel Forum
Old 03-01-2013, 07:06 AM
I have a 97 f250, it just started doing this. When I get up to about 55 it starts to shake like crazy. If I get up to about 80 it will stop shaking and then i can slow down to about 65 and it won't start shaking again until it goes below there. The entire truck is shaking, its not just the steering wheel. It's a pretty violent shake. Any ideas?
Old 03-02-2013, 12:07 AM
im having the same issue. got the truck stuck in the mud 2 weeks ago and it started doing this. i get a slow almost unoticeable wobble/bouce at 30 and shaking at 55-62, and 70+...mine in kinda oscillating though...will do it for 30sec-2min the smooth out for 1-3mins
Old 03-02-2013, 04:31 AM
A bent drive shaft can do weird things.
Sent from AutoGuide.com App
Old 03-02-2013, 04:41 AM
Have your tires balanced.
Old 05-11-2013, 12:39 PM
Truck shakes violently at 55 mph
I had the same problem but the shaking would start around 30 mph, I jacked the truck up and put it in gear while ideling, I noticed the drive shaft wasn't running true by the back axel so I put in a new universal, but I noticed that it didn't fit tight in the yoke? I had the same runout. Had to replace the bearings in the punkin along with the gears because they were worn too much.
Old 05-14-2013, 02:51 AM
The one that was stuck in mud, check inside wheels. Mud will pack on rims and throw weight off. Wobbles like crazy.
Old 05-14-2013, 08:27 AM
check your carrier bearing, u joints, bent axle, and un balanced tires, these all can kause this
Old 05-18-2013, 07:49 PM
I agree with everything. Thorough inspection, good jack stands, wheel choks. Flashlight. Be safe doing the inspect tho.
