rearend help
I need to replace my pinion and carrier bearings in the rear differential. anyone have a write up or can walk me thru it. Also would anyone have the part numbers for this I went up to napa to get the bearings and they looked at me like i had no idea what i was talking about. Thanks for the help.
Look for a master kit form Yukon. Replacing the bearings is going to require you to setup the gears so you will need shims, a clam shell bearing puller and a press. Check out pirate 4x4 for some good writeup on setting up gears.
thanks for the info. Im not sure where I should start beginning to start tearing this rearend down
Before you start, do some reading on what's needed. Setting up gears is not something most people can tackle by them selves. Just the bearing puller that you will need is over $300 for the cheep one. The basic process is to pull the shafts out, pull the cover, mark the bearing caps for side and direction, pull the caps off, pull the carrier out, unbolt the pinion and hammer it out making sure it doesn't take off and fall on the ground, pull the bearings, measure the shims. Install equivalent shims, press new pinion bearing into place, install pinion and set preload. Install bearings and shims on carrier, install carrier in diff, check gear pattern. Remove everything again, change shims, reinstall, check pattern, repeat as necessary till pattern is good or you go insane. Reinstall shafts, fill with oil and drive.
well thanks for the help. im actually thinking i might have to get it to a garage. im limited on time between work and school. so i cant be doing both and working on it.
MTCW - Bill |
