ABS Sensor. - Ford Powerstroke Diesel Forum
Old 11-15-2012, 01:13 PM
ABS Sensor.
Having a hard time locating anything that shows where the ABS sensor is on my 1995 Ford F-350 7.3 liter PS Diesel.
I have found in text that it is on the differential not the wheel housings.
Would that be a single sensor for both rear wheels or one for each wheel?
Anyone have a photo of the sensor(s) so I would know what I'm looking for when I get a chance to actually look?
And how hard is it to change the sensor(s)?
After I start my truck. the ABS light comes on and stays on. I am assuming it is the sensor(s).
The brakes work fine. This winter I will find out if the ABS system works at all. Nice iced up parking lot will test em good. Assuming we get any snow or ice this year.
Thanks.
Old 11-15-2012, 03:18 PM
it is a single sensor on top of the rear diff. it is fairly easy to find just follow the wires to the plug.
to change just unplug and remove the single bolt, i think it is a 10mm but it has been a while since i had o change one, and pop it out.
Old 11-15-2012, 03:58 PM
Thanks. Greatly apreciate the help. Sounds real simple and cheep fix.
