swapped a 1989 sterling into my 1995. now i got no speedo. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-14-2012, 03:36 PM Thread Starter
nightmare95's Avatar
hey guys i need some help. i swapped in front and rear diffs out of a 1989 f350 into my 1995 f250. i switched them both because they both had 4:10 gearing and detroit lockers front and back. After driving it down the road i realized that the plug on the rear diff is supposed to run the speedo, odometer etc. transmission shifts crappy now. the 1989 speedo ran off the transfer case. Now what do i do??
any help greatly appericated.
nightmare95 is offline
post #2 of 8 Old 09-14-2012, 08:42 PM
Quoted: 48 Post(s)
get a GPS
drunk on diesel is offline
post #3 of 8 Old 09-14-2012, 08:45 PM
spool up that turbo!!
hollister25073's Avatar
I can't get the link on my phone but the centurion 6 door bronco thread he found a way to build a tone ring on the rear end
iPhone auto correcting incorrectly like a boss
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #4 of 8 Old 09-16-2012, 06:38 AM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Originally Posted by drunk on diesel View Post
get a GPS
That won't help with his shifting.
The best thing I can think of is take the gearing out of the 89 rear install it in the 95 rear and put the 95 rear back under the truck and chalk it up to lesson learned.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 8 Old 10-16-2012, 02:55 AM
burmad69's Avatar
No tone ring will affect shifting your pcm reads speed to modify shift patterns, only thing you can do is install a tone ring IMO
1997 F-350 PSD CREW LONG BED, BANKS DOWN PIPE,CUSTOM EXHAUST,BANKS TRANS-COMMAND, EGT,BOOST,TRANS TEMP.FPR SHIM, GUAGES.PIAA DRIVING LIGHTS,MY CUSTOM INTAKE,DIY INJECTORS
My house is guarded by SMITH&WESSON 4 nights a week. You Guess Which Ones!
I DONT DIAL 911
burmad69 is offline
post #6 of 8 Old 10-16-2012, 07:46 AM
This guy is totally right.
85_305 is offline
post #7 of 8 Old 10-16-2012, 10:09 AM
Quoted: 50 Post(s)
.... or a ZF5.....
madpogue is offline
post #8 of 8 Old 10-16-2012, 10:30 AM
TANPOWERSMOKER's Avatar
Originally Posted by madpogue View Post
.... or a ZF5.....
I second that motion!
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
