High Steer or Crossover?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-20-2012, 09:25 AM Thread Starter
c0ckeddiesel's Avatar
My stock tie rods are shot and I am getting a vibration or "bumpsteer" (not sure what bumpsteer really is, someone please explain more if you can) Just had an allignment done my tie rod boots are busted and had play in them when lifted up.
I was looking at a beefier steering system due to the lift and me going offroad sometimes but not really trail riding. I have looked at the complete system for at Bullet Proof Steering but its for a 1 ton. Will this work? Also, my leaf springs are in the way for the draglink to connect per thier measurment guide. Anyway around this?
Is there a different system to put it? What does everyone one else have. Need to get one soon because tie rod ball joints are on the verge....
Ne Desit Virtus "Let Valor Not Fail"
UNTIL WE FORM AGAIN...RAKKASAN!!!
1996 F250 7.3L
Edge Evo ---> about to rip that SOB out
K&N Cold Air Intake
37 ProComp Extreme A/T
Rough Country lift
2'' wheel spacer/adapters
CCV Mod
c0ckeddiesel is offline
post #2 of 11 Old 07-20-2012, 10:13 AM
bump steer can happen from a lift. It means your steering is constantly searchign back n forth. A steering stabilizer helps with that greatly.
85_305 is offline
post #3 of 11 Old 07-20-2012, 10:32 AM Thread Starter
I only have a single stabalizer prob should upgrade to a dual...
1996 F250 7.3L
K&N Cold Air Intake
Rough Country lift
CCV Mod
post #4 of 11 Old 07-20-2012, 10:39 AM
for 37's and a good lift... hell ya. But before you do that rip the k&n bs outta there.
85_305 is offline
post #5 of 11 Old 07-20-2012, 10:49 AM Thread Starter
HAHA thats what I am looking at. I am about to pick a 6634 up on the way home.
1996 F250 7.3L
K&N Cold Air Intake
Rough Country lift
CCV Mod
post #6 of 11 Old 07-20-2012, 10:59 AM
good deal my man Def fix those tie rods, those will cause a ton of sway and bump steer. Check the angle of your pitman arm... is it designed for a lift? You need a dropped pitman arm. Check your sleeve adjusters also.
85_305 is offline
post #7 of 11 Old 07-20-2012, 12:18 PM
sgt dave's Avatar
Quoted: 3 Post(s)
Check your axle pivot bushings also. F250's are not lift friendly. Lifts throw the steering geometry out of wack.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #8 of 11 Old 07-20-2012, 02:31 PM Thread Starter
Do yall recommend a new set up such as sky, supper runner, bullet proof steering
Sent from my DROIDX using AutoGuide.Com Free App
1996 F250 7.3L
K&N Cold Air Intake
Rough Country lift
CCV Mod
post #9 of 11 Old 07-21-2012, 04:26 AM Thread Starter
Bump
1996 F250 7.3L
K&N Cold Air Intake
Rough Country lift
CCV Mod
post #10 of 11 Old 08-17-2012, 07:03 PM
leojr's Avatar
Quoted: 4 Post(s)
Originally Posted by c0ckeddiesel View Post
...I am getting a vibration or "bumpsteer" (not sure what bumpsteer really is, someone please explain more if you can)....
In a perfectly designed front-end the suspension pivot points and steering linkage pivot points allow each wheel to move up and down within its suspension travel so that the steering linkage does not affect the turning direction of either wheel. Especially important on road racing type vehicles, not so much on large lumbering trucks. If you run one wheel up on a Kia and you feel the steering wheel want to rotate one direction or the other, this is bump steer. If you roll through an intersection, over the crown of the crossroad, as you compress both front wheels into the low side of the cross road, and the steering wheel wants to rotate, this is bump steer.
The steering wheel rattle at certain speed is likely poor alignment, worn shocks, bent rims, slipped tire belts or bad tire balance. The 'death wobble' caused at certain speeds is likely the poor condition of various suspension components or the lack of or improperly adjusted support like a panard bar, etc. But these rattles and vibrations are not bump-steer. They may cause a bumpy steering wheel, but the are not bump-steer.
Or something like that....
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
