Front Hub HOTT - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-10-2012, 08:14 AM Thread Starter
Brfootball45's Avatar
Send a message via AIM to Brfootball45
Front Hub HOTT
Im having a problem with my front drivers side hub. I recently replaced both inner and outer wheel bearings. Filled with grease and everything, The hub seemed fine, so i didnt pay attention to it. But now it gets hot to touch the chrome piece on the end of the hub, I have manual hubs. Im thinking the locknut could be to tight. If you jack up the front end then try spinning the wheel it goes between a 1/2-3/4 spin then stops. any suggestions would be great
Brfootball45 is offline
post #2 of 10 Old 07-10-2012, 08:16 AM
Gaius's Avatar
Quoted: 40 Post(s)
SOunds like your preload is too tight. Time to retorque it.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #3 of 10 Old 07-10-2012, 08:38 AM Thread Starter
so back the locknut off?
post #4 of 10 Old 07-11-2012, 10:07 AM Thread Starter
bump bump bump
post #5 of 10 Old 07-12-2012, 11:23 AM
Gaius's Avatar
Quoted: 40 Post(s)
Inner nut gets 50 lbs (while spinning the hub) then back off a quarter turn. Outer lock nut gets 180 ft/lbs.
05 F350 Crewcab
Gaius is offline
post #6 of 10 Old 07-24-2012, 04:38 AM
vms305's Avatar
ebay has some great deals on hubs
vms305 is offline
post #7 of 10 Old 07-24-2012, 04:56 AM
Powerstroke Techie
justinmix's Avatar
Jack it up, pull the tire and caliper off, and try spinning it again. If it still feels tight then yes, you have the preload to tight. I wouldn't drive it much till you fix it. I've seen some pretty bad failures from to tight of bearing preload.
justinmix is offline
post #8 of 10 Old 07-24-2012, 10:10 AM
If you don't have a torque wrench, you really should be to take the inner nut just barely over finger tight. As soon as all the slack is taken out of the bearings, it's tight enough.
sgg93 is offline
post #9 of 10 Old 07-24-2012, 10:30 AM
Brakes to tight also, would cause less roll. Remove caliper for testing.
letitsno is offline
post #10 of 10 Old 10-09-2014, 02:31 PM
does your front end have vibrations at 45mph cause mine is doing the same thing...
kicklighter1998 is offline
