u joint, can't find the right one. help! - Ford Powerstroke Diesel Forum
Old 05-18-2012, 04:53 PM
this has been a week long process and I'm out of ideas. I have a 95 RCLB f250. my rear u joints gave out (originals with 120k). but now I can't find the right replacement. I tried two different parts suppliers (excluding ford) and every u joint it calls for, the cup is too small and can push them in by hand instead of pressing them and they spin in the shaft and the yoke. the book said the joints were 1.188" and the old ones measure 1.187" and yet they are too small. I also tried older trucks and newer and none work. does anyone have any advice.
Old 05-19-2012, 07:36 AM
Is there a driveline shop local to you? Take the stuff (shaft and joints) down there and have them match it. That's where I went when I needed u-joints on my 94. Cheers!
Old 05-19-2012, 01:39 PM
or should I get another set of spicer 1350's?
Old 05-20-2012, 08:44 AM
you sure the old ones were not spinning in the shaft and yoke and enlarged the hole's?
Old 05-20-2012, 01:09 PM
I don't think so. the old ones took some force to get out. just like the new ones should to go in.
Old 05-20-2012, 02:00 PM
Maby someone put a newer driveshaft in or difrent rear end? Not sure if the ujoints for the 350 are bigger or not. Google it and see if u can find specs
Old 05-20-2012, 02:08 PM
tried that. tried from 88-99, f150-f450. even tried some Chevy and dodge. no luck. only ones I haven't tried were new spicers from ford, they take a day to get.
Old 05-20-2012, 02:14 PM
Just googled it. Everything i found requird a vin code. Sounds like smeone had done some sort of upgrade. Try pirate 4x4.com. its a extream 4x4 site. They will be able to help they mod everthing
Old 05-20-2012, 02:21 PM
the truck is all original. I bought it off the original owner which is a family friend.
Old 05-20-2012, 07:11 PM
RCLB 97 Every after market Ujoint I tried went in snug then started spinning the caps shortly there after. The only ones that fit right and lasted came from FORD. Cheaper in the long run to buy from FORD.
