2nd gear grinds - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-10-2012, 12:16 PM Thread Starter
2nd gear grinds
hey whenever I try to downshift to 2nd it grinds badly until I slow way down.
Is this a syncro issue? my clutch pedal bushing is worn. I didnt know if that would effect it or not. I assume there not adjustable.
TOW RIG is offline
post #2 of 14 Old 05-10-2012, 05:30 PM
Nitro41's Avatar
replace the bushing before it starts wearing the medal hard parts.
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #3 of 14 Old 05-10-2012, 05:47 PM
elrojo63's Avatar
Is the truck hard to start in the morning? Do you have to kick the pedal down really hard for it to crank? If yes then it's could be a clutch pedal bushing and you should replace the bushing for now and look into getting a heim joint installed for a permenant fix..
If that's not that then 2nd gear synchros are going bad and you should learn how to double clutch well or waste the money on a tranny rebuild. I barely even use 2nd downshifting anyways.
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #4 of 14 Old 05-14-2012, 10:11 AM Thread Starter
everything seems normal in the morning, its just got some play in the pedal.
didnt know if it could be connected.
TOW RIG is offline
post #5 of 14 Old 05-15-2012, 07:52 AM
elrojo63's Avatar
Some pedal play could be connected and probably caused my the pushrod bushing.
elrojo63 is offline
post #6 of 14 Old 05-16-2012, 09:29 AM Thread Starter
I tried double clutching, didnt help. I guess its a syncro issue that I will learn to deal with.
TOW RIG is offline
post #7 of 14 Old 05-16-2012, 12:29 PM
elrojo63's Avatar
You double clutched wrong then. If you do it right it will go into gear without grinding. Gotta rev pretty high to match the speed.
elrojo63 is offline
post #8 of 14 Old 05-16-2012, 05:18 PM
Quoted: 58 Post(s)
Either that, or it's not the synchros. Any play in the pedal probably means it's not pushing the pushrod far enough, thus the fork isn't fully disengaging the clutch. Look at the hydraulics and pedal mechanicals first.
madpogue is offline
post #9 of 14 Old 05-16-2012, 07:59 PM
elrojo63's Avatar
But if you don't use the clutch you can still rpm match to the gears and not grind. Could be the clutch not disengaging fully but should still be able to not make it grind but definitely an issue to get resolved quickly.
elrojo63 is offline
post #10 of 14 Old 05-18-2012, 05:57 AM Thread Starter
I also noticed yesterday that when you go to third if you let go of the shifter it will fall out of gear. but if you keep your hand on it it does fine, with no grinding.
TOW RIG is offline
