Power steering pump is about 1-1/2 yrs old and when I changed it I used Lucas ps pump fluid.
So here is what happened today/tonight. I drove my truck to and from a few errands today, all less then 2miles from home. About 3-4 hrs between trips. had zero issues Parked the truck in my drive, and it sat there the last 2-3 hrs? An hr ago I pulled it out of the drive, made a HARD right and parked it on the curb and shut it off while I pulled in my minivan. Zero issues 20 min later I come out side to run to the grocery less than a mile away. I crank the truck and go to drive off and I have zero PS. I continue to the grocery, shop for 20min, then drive back home with NO PS. Then just as I enter my subdivision the Power Steering kicks back in and does fine for the next 6 turns all the way into my drive.![]() So I'm here to run my gums about it..... and then go searching for answers Should be a simple fix, I'm thinking I might need a fluid flush or something. Any other thoughts? off to searching I go
Alright well most of the info I'm finding is pointing towards a failing PS pump.
I'm still thinking about a sticking valve or possibly trash in the lines due to deteriorating hoses or something. I think I'll suck out and replace the fluid in my reservoir tomorrow and just drive carefully. |
Just got back from a 2-3 mile ride.
Truck did fantastic, no sign of Power Steering issues. I'm still going to go out and change the fluid later on today. |
Is it possible something got on the pulley and made it slip?
Interesting concept, and surely it could be a possibility.
However I did not previously drive in any adverse road conditions, and the hood hasn't been opened in a few wks. and we haven't had rain in a few days. My serpentine belt has seen better days though, and I do get a squawk out of it almost every time I shut off the engine. Thanks for the input. I'm running out to Napa once they call me about the arrival of the parts for my/our minivan, then I'll pop my hood after doing my wife's brakes and see whats up with my truck. |
Well I meant more like if something might be leaking onto it. I know this is a totally different animal but my grandmothers Subaru was having intermittent power steering issues and while in there I also noticed she was low on coolant. Her coolant was leaking onto the belt which was then slipping over the pulley.
Sent from my DROID BIONIC against my will |
Ahh Haa, I get it.
I'll make sure and check while I'm in there. Thanks. |
Check you brake boost vacuum pump. Had a similar issue a while back. Solved itself on my way home however when the v/p decided to chew a bearing and shred the belt. My best guess is that the seal/bearings being worn caused it to drop some brake fluid on the p/s pulley when I parked the truck.
does it matter that I did nothing?I went out and checked the fluid level and it was fine....... Things came up and I left the truck alone. I've been driving the snot out of it though with no issues.
