High revvin - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-05-2012, 01:48 AM Thread Starter
Whitewhale7.3's Avatar
High revvin
Hey all, not sure if this is a problem, but I was wondering why I'm revvin around 2300 rpm around 55-60 mph in my 96 f 350 7.3 DI dually extended cab... Is there different rear diff ratios for this year and model I'm thinking about changing the ratio to get higher mph and lower rpm since I commute about an hour to and from work any info would be appreciated!! Thanks for the time
Whitewhale7.3 is offline
post #2 of 5 Old 04-05-2012, 02:18 AM
Turbostang500's Avatar
If you look on the tag that is attached to the rear end housing with a cover bolt, that should have at least the original gear ratio on it.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #3 of 5 Old 04-05-2012, 03:09 AM
Quoted: 5 Post(s)
im at 72 at those rpms in my 95 dually. i have 4:10 gears. whwn my TC wasnt locking i was about where you are
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #4 of 5 Old 04-05-2012, 07:16 AM Thread Starter
How would I go about finding out if my TC isn't locking... Would a tranny fluid and filter change help out with this problem if it is even that???
post #5 of 5 Old 04-06-2012, 07:30 AM
JD3020's Avatar
When your cruising down the road, and the truck is up to temp, when you let off the throttle do the RPM's drop or do they stay the same? If the converter is working it should lock-up around 31ish mph, and it will feel like another gear in between 3rd and OD.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
