front spring help. - Ford Powerstroke Diesel Forum
Old 03-04-2012, 09:24 AM
front spring help.
So i traded my cummins for a 97 F250 stroker 4x4. Heres the problem. The last owner had a snowplow on the truck and the front springs are shot, not to mention the idiot stuck aluminum blocks up front to level it out. My question is what spirngs will fit under the front of the truck. I like where the ride height is now, what im wondering is will 1 ton springs from a truck the same yr fit, or even super duty springs.
And also there is a bracket that holds the left side i beam which is on the back side, they put some washers in between the bracket and frame can i take these out because the bracket is bent a little bit.
Old 03-05-2012, 01:36 PM
bump.........
Old 03-06-2012, 10:32 AM
How about some pictures to show what is going on. Is this the truck with 6" lift? There should be no washers between the pivot bracket and cross member.
Old 03-06-2012, 01:15 PM
No thats my old truck this truck has a cobbled up lift on it, i will c if i can get some pics of what im talking about.
