carrier bearing problem maybe? - Ford Powerstroke Diesel Forum
Old 02-13-2012, 05:28 PM
Everytime I gas on my 97 f350 5spd there's a loud bang noise under the truck at 1st I thought it was axle wrap then i thought it was the carrier bearing but im not to sure maybe someone can narrow down the problem.
thanks
Old 02-13-2012, 05:41 PM
Or the slip joint. It comes with just teflon coating from factory. I drilled, tapped, and put in a grease fitting to it. Works great now.
Old 02-13-2012, 05:52 PM
ok ill check and try that thanks
Old 02-14-2012, 07:46 AM
Originally Posted by 97GreenMachine View Post
Everytime I gas on my 97 f350 5spd...
There's your trouble. Try diesel fuel; gas doesn't burn in our trucks...
KIDDING. Are you on the original clutch/flywheel? Could be the dumb-mass...er... dual-mass flywheel starting to let go.
