Oil Dripping Off of Rear Drive Shaft - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-11-2011, 07:11 AM Thread Starter
I have a small oil leak dripping off of my rear drive shaft right behind the transfer case. It is a slow leak that only leaves a small spot on my garage floor every night. I replaced the seal between the transfer case and the drive shaft and it did not fix the problem. I have oil on the muffler and all under the truck where that seal is from where it throws oil while the drive shaft is spinning. Any suggestions to where else the leak could be coming from? How often are these seals bad from the parts store? I purchased the seal at NAPA and it was installed by a mechanic here at the Ford dealership I work at. Any suggestions would be greatly appreciated. I am about to have in put in a red head gearbox for me and figured I might as well have him take a peek at this for me as well.
Rashole is offline
post #2 of 5 Old 11-18-2011, 01:13 PM
POWERSMOKIN's Avatar
what color is this oil?
Red= ATF (used in transmission and transfer case)
Black = Engine Oil
Brown AND smelling bad = Gear oil
And grease would be obvious
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #3 of 5 Old 01-06-2012, 08:57 AM Thread Starter
It appears to be engine oil. I did notice some ATF fluid the other day too. I am looking into replacing the ujoint and yoke. I think it may cost just a little more for a new or reman driveshaft though. Any suggestions on where to find one?
Rashole is offline
post #4 of 5 Old 01-06-2012, 09:28 AM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
Unless you have a CCV exiting there, I can't fathom how engine oil could be the culprit since there is nothing but ATF inside everything all around that area. I would redouble my efforts on scrutinizing the transfer case seal that was just replaced. It's very possible the seal was damaged during installation?
Was the driveshaft yoke damaged?
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #5 of 5 Old 01-06-2012, 09:47 AM Thread Starter
That is what I am leaning towards right now. We have an awesome drivestrain company here in Dayton so I am going to send the driveshaft to them and have a new one built. They a little over half the cost of the yoke and ujoint for a whole driveshaft. I am going to replace that seal again as well. Thanks for the input.
Rashole is offline
