Spindle socket size? 97 F350 4x4 - Ford Powerstroke Diesel Forum
Old 10-20-2011, 07:30 PM
Replacing the ball joints on my 97 crew F350 4x4. Disassembling down to the axle shaft nut. Did a search and not finding the size spindle socket I need or where to purchase it. Has automatic lock.
Thanks.
Another question, the threads I have seen said there should be a snap ring inside the hub to remove. I've takin it down to the axle shaft nut already and did not see or remove a snap ring.
Old 10-21-2011, 02:12 AM
Hillbilly Deluxe
Feedback Score: 3 reviews
I believe the snap ring is ahead of the nut, kind of like a retention ring... Not sure on the nut size, but the last time i did it i was able to rent the entire kit from Autozone.
Old 10-31-2011, 06:52 AM
The big nut is a 2-3/4 hex, I got Performance Tool W9346 from O-reilly's.
If you install locking hubs, the big hex nut goes away and a spanner socket is used.
DR
