Axle Seal Leak - Ford Powerstroke Diesel Forum
Old 06-26-2011, 06:17 PM
Axle Seal Leak
Howdy Yall,
Came home today to find a little puddle on the ground underneath the passenger end of my axle. I thought maybe my ball joint lost its grease but upon closer inspection, its wet inward of the U-Joint. My bearings (including needle) and u-joints were replaced about a 1-1.5 years ago so I assume the seals were too. Is this an outer axle seal? How much work is this to tear into? How about cost for a shop? I'm very mechanically inclined but just never had to tear into my axle past the brake rotors. Thanks!
Old 06-26-2011, 06:29 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
That outer seal is just a dust seal. There is an inner axle seal that stops oil from coming out. I dont know how that one comes out but it is not hard to get there. Mise well do the ball joints too and u joint while you are in there.
Old 06-26-2011, 06:46 PM
Thanks for the reply. After further reading I assume its the inner seal now. I've read that the axle shaft needs to be pulled (obviously) which seems like kind of a pain for a first-timer. I guess I'll check the level of the differential first and make sure it isn't overflow. Also I had the ball joints and u-joint done 1-1.5 years ago so those should be good still.
Forgot to mention its my front axle and auto hubs shouldn't be engaged when in 2wd (99% of the time I am) so I guess it's not too urgent to address this before a trip this coming weekend huh?
Old 07-13-2011, 03:28 PM
Electrical Ogre
Before you tear into it, check the vent hose. They can plug up with crap, then push oil out the seals when it warms up. Not so likely on a front diff, but worth checking.
Old 07-14-2011, 06:45 PM
does anyone have part numbers for the axle components? I want to rebuild mine, and I was going to order off RockAuto; just want to make sure I get the right stuff.
