1997 F350 Dana 60 Outer tube dust seal - Ford Powerstroke Diesel Forum
Old 06-22-2011, 08:12 AM
Send a message via AIM to FORDF35073PSD
I have been looking for a part number for the outer tube axle seal for a 97 F350 dana 60 axle. This is the seal that goes on the inner shafts and seals dirt out of the axle tubes. any Ford, Motorcraft, SKF, Timken, National, etc.. any part number will be of great help!
Old 06-22-2011, 09:16 AM
Bump....
Old 06-22-2011, 09:26 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
Call up an advance auto parts. I know the one by me sells em.
Old 06-22-2011, 03:24 PM
Electrical Ogre
There are no seals on the outer end of the tube on the OBS D60. They started installing them on the SD trucks. There are kits available to do it on an older axle.
Dana 60 Outer Axle Seal [D60-OuterSeal] - $65.00 : Mad 4 Wheel Drive
If you are leaking gear oil, you need to pull the cover and axleshafts, then remove the center section to replace the inner differential seals.
Old 06-22-2011, 07:01 PM
Ended up using Motorcraft BRS-86 seals, fit perfectly and will do the job also only cost about $8.50 a piece.
Tags
axle seal, dana 60, tube seal
