VSS - Ford Powerstroke Diesel Forum
Old 05-05-2011, 12:07 AM
VSS
Still have not gotten trany problem solved heres a couple questions that came up 1. is there a difference between a 1995 and a 1997 tone ring in rear end.
2. should the wires going into sensor on top of rear end housing be able to spin around and if not i read you can buy a pig tail and splice a new end on it and will the wires be color coded.
Also how do tell the difference between a 10.25 and a 10.50 rear end as i was thinking the rear end we used to put a dually under our 95psd could be a 10.50
instead of a 10.25 if that makes any sense or difference,thanks
