ball joints or something else? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-17-2011, 04:17 PM Thread Starter
so when i drive down a straight smooth road the truck will be fine then all the sudden the truck will hop left and will continue to pull left then a few moments latter hops right and pulls right. then it may go back straight or left just kinda back and forth. im thinking ball joints. maybe something else how would i check the ball joints or check if its something else? any ideas much appreciated
thanks,
jim
zombiediesel is offline
post #2 of 9 Old 04-17-2011, 04:20 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Jack up the truck and try to shake the tire 12 and 6
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #3 of 9 Old 04-17-2011, 04:39 PM
Try greasing the front end I had the same problem after I purchased mine
Bobo is offline
post #4 of 9 Old 04-17-2011, 05:41 PM Thread Starter
Jacked up the truck and absolutely no play on either wheel I'm guessing that's good ill grease it up sometime this week when I have more time
post #5 of 9 Old 04-17-2011, 05:42 PM
studdgage's Avatar
check the sway bar bushings and all the other bushings had something similar the sway bar bushing went out on mine.
Some people are like slinkies they are completely useless but they still bring a smile to your face when you push them down a set of stairs
studdgage is offline
post #6 of 9 Old 04-17-2011, 05:56 PM
usnavyad's Avatar
Not Ur ball joints then bud
GPDA's other shawn
usnavyad is offline
post #7 of 9 Old 04-17-2011, 06:23 PM
Powerstroke Techie
forddieseldoctor's Avatar
Take the tie rod off of both wheels and see if you can turn each wheel in the air. You could have a stuck u-joint or a stiff ball joint.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #8 of 9 Old 04-17-2011, 06:30 PM
usnavyad's Avatar
Ball joints are a pain on our trucks
GPDA's other shawn
usnavyad is offline
post #9 of 9 Old 04-19-2011, 08:02 PM Thread Starter
So I havent taken of the tie rods but the bushings on them look pretty bad ill check the sway bars and take the tie rods off to check u joints
