96 powerstroke brake problems - Ford Powerstroke Diesel Forum
Old 02-11-2011, 09:46 AM
Last night i was turning my truck around and lost all power assist on my brakes. I dont know if its the brake booster or the vacum pump. I have no power assist at all now and it just stopped workin all of a sudden. I was hoping you could help me diagnose it.
Old 02-13-2011, 05:34 PM
Try changing your vent from defrost to vents if it doesn't switch it would be the vacuum pump. Check the hoes off the vacuum pump for cracks in the hoses. I had the same problem and found it was the vacuum pump. Good luck and post your findings.
Old 02-18-2011, 05:39 PM
I got mine fixed it was the vacuum pump so i swapped it and everything is good now but thanks everyone for your help
