Frontend and Dana 60 full rebuild? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-05-2011, 11:23 PM Thread Starter
1950gmcelc's Avatar
I have a 95 F350 with the dana 60 front. My truck has 250,000 miles on it and I don't think the front has ever been rebuilt. The axle is leaking from the axle tubes on both ends. Also my tires look like the tops are leanin in. I am planning on doing new inner seals, ball joints, tie rods, maybe wheel bearings, maybe carrier bearings, new energy bushings on everything. What brand joints do you guys recommend? I was either going to use Moog or Napa Chasis brand.
Does anyone have a full write up on a complete dana 60 rebuild and a parts list? Also what else would you guys recommend replacing or changing while I am in there. I was also wondering since I am running 35"s should I do a single or dual steering dampner?
The next question I have is what shocks do you guys recommend running I wanted to run the Bilstein 5100s cuz they look cool even though they are built for a llifted truck. Should I run the 5100s or would I be better off with the heavy duty shocks. Are Bilstiens worth the money on a F350 or should I just get a cheaper shock?
Sorry for such a long post but I am trying to get all the info I need and figure out what this rebuild is going to cost before I jump into this job. Thanks for any help you guys may be able to give.
1950gmcelc is offline
post #2 of 8 Old 02-06-2011, 06:34 AM
TxAG'97's Avatar
Extreme Axle Sales
Pirate4x4.Com - Extreme Four Wheel Drive
This will give you a start on parts, kits, and someone to call and talk to. I used them both when I rebuilt my King Pin D60.
As for the shocks I will be buying Bilstein again when the time comes - I will also be calling CaryT (a member here search for him) he will get you a really good price for most of your needs.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip, Stage 1's, BTS
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear Replacement Clear Headlights
Ruff Tuff Seat Covers, Westin Nerf Bars
16x10 Pacers W/315 75x16 Duratracs
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
TxAG'97 is offline
post #3 of 8 Old 02-06-2011, 08:10 AM Thread Starter
1950gmcelc's Avatar
Did the Bilstiens make that big of a differance in ride?
post #4 of 8 Old 02-06-2011, 09:24 AM
TxAG'97's Avatar
It did for me and I bought the cheapest that Bilstien had to offer because I was a little skeptical due to their prices. They are the 4600 series - the yellow and blue - and on the next set I will upgrade.
Most importantly
TxAG'97 is offline
post #5 of 8 Old 02-06-2011, 10:01 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
bilstiens are good stuff.. made a big diff. on mine but my shocks were shot. think i got the 5100s
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
Ø-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #6 of 8 Old 02-11-2011, 09:08 AM Thread Starter
1950gmcelc's Avatar
Will the 5100's work on my truck without a lift? I know it sounds stupid but I like the silver better then the yellow. I am running 35's with no lift.
post #7 of 8 Old 02-11-2011, 09:20 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
put in a locker i did when i swapped a D60 into my truck. and moog makes great stuff
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 8 Old 02-12-2011, 09:27 AM
I agree, go for the locker while you are in there.
kb2red is offline
