Wheels bowing out bad in reverse - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-11-2011, 01:40 PM Thread Starter
I have a 1997 PSD twin i beam front end. The truck has 4 inches of lift on it. Just recently it the tires started bowing out really bad when i back up. It has always done this a little but now it's getting bad. I have heard some say that the leafs in the front can go bad because of the weight of the engine. Mine are arched backwards from the back ones (they arch down instead of being flat or arching up). My question is does anyone think this is causing my tires to bow out more than normal. The tires are wearing great so everything is fine when i'm moving forward. thanks in advance
woodduck73 is offline
post #2 of 6 Old 01-15-2011, 10:32 AM
95redrifle's Avatar
Quoted: 3 Post(s)
mine does it too. i replaced ball joints a few months ago and it got better but its still not perfect not sure what else causes this though
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #3 of 6 Old 01-24-2011, 03:11 PM
ryandamo's Avatar
if it has 4 inches of lift, the springs should not be arched backwards unless you are using a shackle flip and stock springs
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #4 of 6 Old 01-28-2011, 08:24 PM
Mounsey47's Avatar
you may also want to try lookin into geting some new inner and outter wheel barrings. they seem to help quite a bit as well when i had this problem.
Mounsey47 is offline
post #5 of 6 Old 02-04-2011, 08:27 PM
from what i learned when i had an 87 bronco, espically if you turn while backing up to park the ttb almost always does this, on some trucks its to little to notice but on some its very pronounced, my bronco looked like a wheel was about to fall off at times depending on how i parked it but as soon as i'd move forward a little it was right back in line like it should be
97 F250 7.3 PSD, 4x4, 5 Speed, Super Cab, 8ft Bed
SuperMidget is offline
post #6 of 6 Old 02-04-2011, 08:29 PM
nine6stroker's Avatar
Quoted: 35 Post(s)
My suggestion, if you can swing the cash, get rid of that pile they call a TTB and swap in a D60. Best $1,200 I've invested in my truck so far (paid 850 for the axle, F350 springs, track bar, sway bar, u-bolts, and the other $350 was other stuff I bought associated with the swap). Rides better, handles better, looks better, etc...
I don't really know what to tell you about the bowing though... Do a search for a thread called "OBS Chat" and ask about it in there. Some of the guys in that thread know more about these OBS trucks than a lot of mechanics do.
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
