Break booster pump - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-26-2010, 12:49 PM Thread Starter
Break booster pump
I'm I on the right track? My breaks are hard and I don't get much breaking. Seems like the I lost the power breaks. Is this a sign of the booster going bad. How much of a job is it.
Thanks for the help.
Hunter
bfr44 is offline
post #2 of 9 Old 12-26-2010, 01:04 PM
I think If you are talking about the vac-pump, if you ac/heat duct system works while you apply your brakes it is probually good.
MikeyK is offline
post #3 of 9 Old 12-26-2010, 01:30 PM Thread Starter
Mikey,
Just tried it and it didn't change from defrost to vents while my foot was on the break. So I guess I need a vac-pump. How hard of a job is it?
Thanks
Hunter
bfr44 is offline
post #4 of 9 Old 12-26-2010, 02:01 PM
ryandamo's Avatar
hardest part is getting the old pulley on to the new one if it doesnt come with it. Rent a pulley puller and it just pops off, other than that, take the belt of, remove vaccum line , unbolt the old one and bolt in the new one
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 9 Old 12-26-2010, 03:05 PM
My '99 vacuum pump is electric, when you turn the key on you should hear it doing a fast click, it is mounted on the ps inner fender, mine stopped and I lucked out, it was the connection.
MikeyK is offline
post #6 of 9 Old 12-26-2010, 08:04 PM
ryandamo's Avatar
94-97 trucks dont have electrical vacuum pumps, they are mechanical and are driven by the serpentine belt
ryandamo is offline
post #7 of 9 Old 12-26-2010, 08:15 PM
Thanks for that update .. Good 2011 to you.
MikeyK is offline
post #8 of 9 Old 12-28-2010, 08:58 AM Thread Starter
The pully isn't poping off with a puller. Any hints? Heat?
Thanks
bfr44 is offline
post #9 of 9 Old 12-28-2010, 03:40 PM Thread Starter
I used some heat and it did pop off. Thanks for the help.
bfr44 is offline
