SUDDEN DROP IN LPOP...
could the bypass valve have anything to do with this??? were the oil filter goes there is a spring up in there that fell out,i was told that this is the filter bypass and that hole in there is were the spring goes,as of now im not filtering oil properly,i wonder if this has somthing to do with the lpop psi dropping???? rebuilt motor too...although when i had the motor out,i didnt mess with the lpop pump,wonder if that thing is going out??? god!!! hope i dont have to pull the motor to get to the lpop....do i???
figures.. well lets sent who ever voted yes on this needs to be replaced period...
the lpop is around the crank damper so if you need to replace it you dont need to pull the moter could be the bypass valve by the filter
